silverous
Apr 08, 2013Aspirant
Rsync impact on disks?
Hi, I have a Readynas and an iMac. I'm new to the Mac world however my question is more general than mac-specific. My intention is to synchronise "Media" files (photos, movies etc.) between my iM...
silverous
StephenB wrote: Normally you would use rsync incrementally. Then it looks at the file name, size, and modification date in the directory of both systems. If a file's size and timestamp don't match (or if the file is new), then the file is copied. Otherwise it is ignored.
Also, note that SSD wear only occurs when writing to your Mac. Reads on the SSD are not a concern.
Excellent, thank you. In terms of looking at the file name, size and modification date I presume that means it isn't looked at the actual data but just the "index" to the data.
