RuudB
Jul 13, 2017Aspirant
Rsync on ReadyNas Duo v1 not running anymore
My ReadyNAS Duo v1 works perfectly (why do you call it end of live :-). ) Due to a disk crash, I had to install a new 2TB disk and unfortunately I also reset the NAS, which means that all backup job...
- Jul 16, 2017
Hi StephanB,
Thanks for your reply, sorry for my late response; busy :-(.
Thanks to your determination that a forward slash was needed, I went to search again (googling). Now I finally found it in one of the messages I encountered the correct syntax.The syntax must start with 'root', so the full syntax must be 'root/users/[username]/[Directory]/[Directory]/'.
The syntax is case sensitive and the target directory must be on the target. The directory name must not contain space or punctuation. The forward slash at the end is a must.Problem solved.I now have saved the syntax in my OneNote, so I don't I will lose ever again :-).Thank you very much for your help.RuudB.
RuudB
Hi JennC,
Thanks for your early reply.
I can give some screenrpint, but they are only in dutch, sorry. I tried to get them in English but it didn't work.
I put the screenprints in a pdf, you can download it from here:
https://1drv.ms/b/s!AtA0QTMANX0QmnuEcfIP4hEcSSt-
Regards RuudB
JennC
Jul 14, 2017NETGEAR Employee Retired
Hello RuudB,
I recommend to check the permission of the share of the NAS which have set as the source. I have questions too.
- What happens when you test the connection on step 2?
- Are you able to ping the destination using its domain name?
- Have you tried using IP address on the destination field of the backup job instead of domain name?
- What is the firmware version of your ReadyNAS?
