RuudB
Jul 13, 2017Aspirant
Rsync on ReadyNas Duo v1 not running anymore
My ReadyNAS Duo v1 works perfectly (why do you call it end of live :-). ) Due to a disk crash, I had to install a new 2TB disk and unfortunately I also reset the NAS, which means that all backup job...
- Jul 16, 2017
Hi StephanB,
Thanks for your reply, sorry for my late response; busy :-(.
Thanks to your determination that a forward slash was needed, I went to search again (googling). Now I finally found it in one of the messages I encountered the correct syntax.The syntax must start with 'root', so the full syntax must be 'root/users/[username]/[Directory]/[Directory]/'.
The syntax is case sensitive and the target directory must be on the target. The directory name must not contain space or punctuation. The forward slash at the end is a must.Problem solved.I now have saved the syntax in my OneNote, so I don't I will lose ever again :-).Thank you very much for your help.RuudB.
Jul 14, 2017Guru - Experienced User
Your path for the strato server should use forward slashes (/), you are using back slashes (\). There should be no double slash at the beginning.
Are you sure the path itself is correct?
RuudB
Jul 14, 2017Aspirant
Hi JennC and StephanB,
Thanks for your reply.
The Strato server only accepts pathnames with backslash, see screenshots.
Using /users/[username]/Backup/Mijn Mail/ the connection test repies with 'Invalid path'
using \users\[username]\Backup\Mijn Mail the connection test (ping) replies: 'Connected to rsync.hidrive.strato.com'.
The same reply when I start with no-slash or double slash, but think one-slash is correct.
And I think this must be the correct syntax for the path, also the slash at the end of the path name is necessary, otherwise the connection fails with invalid path name.
I run the update firmware, but the latest version (4.1.16) is already installed.
I can't use an IP-adress instead of the strato domain.
JennCWhat permission do you mean, the Rsync permissions?
They are 'Read only'.
Thanks again for helping.
Regards RuudB
- RuudBJul 15, 2017Aspirant
Sorry for double message.
Additional question and notice.
Next to the ReadyNAS I also have a backupjob runnung from my SynologyNAS, not at the same time, but can this 'connection' maybe cause the trouble?
Regards
RuudB
- StephenBJul 15, 2017Guru - Experienced User
Note there is a help button which gives guidance on the path formats for various protocols.
Rsync server
If your rsync server is exporting modules, then:
If the location is: myserver::mymodule/mydir
The host is: myserver
The path is: mymodule/mydir
So it definitely says forward slash, and likely you don't need the starting slash or the ending slash. If the target is a ReadyNAS share, the path is simply the share name.
You could double-check with strato on what the path to your backup repository is. Alternatively you could try restoring it to a different (test) share.
Did you ever save your logs or configuration zip?
- RuudBJul 16, 2017Aspirant
Hi StephanB,
The syntax is case sensitive and the target directory must be on the target. The directory name must not contain space or punctuation. The forward slash at the end is a must.Problem solved.I now have saved the syntax in my OneNote, so I don't I will lose ever again :-).Thank you very much for your help.RuudB.- StephenBJul 16, 2017Guru - Experienced User
I'm glad it's working again.
