RuudB
Jul 13, 2017Aspirant
Rsync on ReadyNas Duo v1 not running anymore
My ReadyNAS Duo v1 works perfectly (why do you call it end of live :-). ) Due to a disk crash, I had to install a new 2TB disk and unfortunately I also reset the NAS, which means that all backup job...
- Jul 16, 2017
Hi StephanB,
Thanks for your reply, sorry for my late response; busy :-(.
Thanks to your determination that a forward slash was needed, I went to search again (googling). Now I finally found it in one of the messages I encountered the correct syntax.The syntax must start with 'root', so the full syntax must be 'root/users/[username]/[Directory]/[Directory]/'.
The syntax is case sensitive and the target directory must be on the target. The directory name must not contain space or punctuation. The forward slash at the end is a must.Problem solved.I now have saved the syntax in my OneNote, so I don't I will lose ever again :-).Thank you very much for your help.RuudB.
Jul 15, 2017Guru - Experienced User
Note there is a help button which gives guidance on the path formats for various protocols.
Rsync serverIf your rsync server is exporting modules, then:
If the location is: myserver::mymodule/mydir
The host is: myserver
The path is: mymodule/mydir
So it definitely says forward slash, and likely you don't need the starting slash or the ending slash. If the target is a ReadyNAS share, the path is simply the share name.
You could double-check with strato on what the path to your backup repository is. Alternatively you could try restoring it to a different (test) share.
Did you ever save your logs or configuration zip?
RuudB
Jul 16, 2017Aspirant
Hi StephanB,
Problem solved.
RuudB.
- StephenBJul 16, 2017Guru - Experienced User
I'm glad it's working again.
