pgn93
Mar 26, 2019Aspirant
Rsync SSH : permission denied
Hi all,
I am trying to save files from my computer (running linux lite) to my ReadyNas 104.
I have created a public key (saved as ~/.ssh/id_rsa.pub) that I have uploaded in the user settings on m...
- Mar 30, 2019
Hi Mark,
Thanks for your answer. I was trying to copy files on a separate share and I solved the issue.
After investigation, I found out what I was doing wrong. My Network drive was mounted as anonymous...
I mounted it under my account (the one I created the authorized key) and it worked like a charm.
Cheers
pgn93
Marc_V
Mar 28, 2019NETGEAR Employee Retired
Hi pgn93
Welcome to the Community!
Are you trying to copy the files to a Home share? Have you tried it on a non Home share? It would be best to create a separate share and try to transfer to it.
Regards
pgn93
Mar 30, 2019Aspirant
Hi Mark,
Cheers
pgn93
