davidr1
Apr 10, 2017Luminary
Script won't run
I have a script in /scripts/ which is where I keep my scripts. Individually, every command works. It is a simple script containing: chown -R --reference=/data/<path1>/<file> /data/<path1>/<file_na...
- Apr 11, 2017
Who is the owner of the script (should be admin, not root, I believe) and did you set the execute bit on it?
