spotcatbug
Feb 22, 2016Apprentice
Scrub feature takes too long to use...
Let's talk about the scrub feature. Is anybody actually using it? I know scrubbing is slow. I expect that. I have the scrub schedule set to do it once every three months. The problem is, it is so...
spotcatbug
Just an update:
I'm now at 2% complete, and it's been going for 4 hours. Extrapolating, that's a total of 200 hours to get to 100%. That's just not doable. 200 hours is more than a full week (8.33 days).
Is there something I can check that may be wrong with my NAS that could cause this? Looking at the output of top, I see three kworker processes, each taking just under 30% CPU. Does this seem right?
Feb 22, 2016Guru - Experienced User
Mine started slow, and then picked up speed - so I'm not sure that you can simply extrapolate.
How much data is in the data volume?
- spotcatbugFeb 22, 2016Apprentice
Data volume is only at 1.85 TB (of 5.40 TB). I get that the scrub speed is going to vary. It already has changed by quite a bit (unfortunately, in the wrong direction).
I'm going to wait this one out for at least a few days, to see how far it will get. But, like I said, the last time it took two days to get to 5%. Unless the next 95% was going to go 38 times faster than the first 5%, it wasn't going to get finished in 3 days.
I guess this is why I'm posting. I'm trying to find out if my NAS is out of whack, compared to other people that scrub.
- StephenBFeb 22, 2016Guru - Experienced User
I'll start one on my RN102 (and hopefully will remember to post speed here). The RN102 is running 6.4.2 (and recently I did a factory reset, which significantly improved performance).
- cpu8088Feb 22, 2016Virtuoso
upgrade to a 214 or 314
104 is a budget model u cannot expect performance
