spotcatbug
Feb 22, 2016Apprentice
Scrub feature takes too long to use...
Let's talk about the scrub feature. Is anybody actually using it? I know scrubbing is slow. I expect that. I have the scrub schedule set to do it once every three months. The problem is, it is so...
Feb 22, 2016Guru - Experienced User
Mine started slow, and then picked up speed - so I'm not sure that you can simply extrapolate.
How much data is in the data volume?
spotcatbug
Data volume is only at 1.85 TB (of 5.40 TB). I get that the scrub speed is going to vary. It already has changed by quite a bit (unfortunately, in the wrong direction).
I'm going to wait this one out for at least a few days, to see how far it will get. But, like I said, the last time it took two days to get to 5%. Unless the next 95% was going to go 38 times faster than the first 5%, it wasn't going to get finished in 3 days.
I guess this is why I'm posting. I'm trying to find out if my NAS is out of whack, compared to other people that scrub.
- StephenBFeb 22, 2016Guru - Experienced User
I'll start one on my RN102 (and hopefully will remember to post speed here). The RN102 is running 6.4.2 (and recently I did a factory reset, which significantly improved performance).
- cpu8088Feb 22, 2016Virtuoso
upgrade to a 214 or 314
104 is a budget model u cannot expect performance
- spotcatbugFeb 22, 2016Apprentice
Honestly, if I'm going to change to a different NAS, it's not going to be in the Netgear family. But I didn't want this thread to go down that road.
If the true answer is that the 100 series isn't capable enough for the scrub feature, I'll accept that. I'd like for more scub users to weigh-in, though.
