spotcatbug
Feb 22, 2016Apprentice
Scrub feature takes too long to use...
Let's talk about the scrub feature. Is anybody actually using it? I know scrubbing is slow. I expect that. I have the scrub schedule set to do it once every three months. The problem is, it is so...
lundmilo
Feb 23, 2016Luminary
I just started a scub on my RN204 with 2 x 2 TB WD Red with approx. 900 GB of data on it.
The NAS was booted the first time on 9th of January and it is the first time i am running a scrub.
It has been running for 50 minutes and is 4.67% complete.
JennC
Feb 23, 2016NETGEAR Employee Retired
Hello spotcatbug,
File system check and RAID resync can take a while as they read entire partition and a bit slow. Both slow down more on a weaker processor like the 100 series. 2 days I think is okay but if it feels that it will take longer than that, maybe you need to contact support center.
