spotcatbug
Feb 22, 2016Apprentice
Scrub feature takes too long to use...
Let's talk about the scrub feature. Is anybody actually using it? I know scrubbing is slow. I expect that. I have the scrub schedule set to do it once every three months. The problem is, it is so...
spotcatbug
Feb 26, 2016Apprentice
UPDATE
OK, I'm back. Factory reset, restore from backup and resync are complete. Now wouldn't normally be the time to do a scrub, but I'm curious if the reset fixed whatever my issue was. I just started a scrub at 18:23 EST. I'll report back when it's done.
