aalexandrebeta
Jun 01, 2016Master
Scrubbing time and percentage
The thing witch surprise me a lot is the way the meter is handling itself it is taking more time to go from 0% to 10% than 50% to 100%!!
- Jun 03, 2016
Hello aalexandrebeta,
Yes, I think you have posted another topic about this and I responded to post it in the idea exchange board. :)
For now can we close this thread?
JennC
Jun 02, 2016NETGEAR Employee Retired
It could be one share with a lot of data compared to other shares.
Scrubbing reads all data from all disks and then verifies checksums. If it sees errors, then it corrects them along the way. Additionally, the default input/output priority of a scrub is idle class, which means that it would slow down if processes are accessing the file system and then pick back up at a later time.
- aalexandrebetaJun 02, 2016Master
Thanks for the ansewr but what I suggest is a meter that shows you the time remaining to execute that task.
- JennCJun 03, 2016NETGEAR Employee Retired
- aalexandrebetaJun 03, 2016Master
Yes, after I posted this one, I was thinking that it would be great to expand it on other lengthy features!
