TomBlack
Sep 06, 2017Guide
SEAGATE ST10000NM0086 Drives
Want to confirm that Seagate's ST10000NM0086 Drive is compatible with a 51600 or a 626X or a 628X NAS. TIA!
- Sep 12, 2017
Hello TomBlack,
The drives that are listed on the HCL gone through testing and proved that work fine with the NAS. As for when the HCL will be updated we have not receive any notification yet from the department that handle it. For now we recommend to get the one's that are listed on the HCL.
Marty_M
NETGEAR Community Team
Marty_M
Sep 11, 2017NETGEAR Employee Retired
Hello TomBlack,
Seagate's ST10000NM0086 is not listed as compatible hard drive under HCL of the NAS. There are 10 TB hard drives that are listed that is compatible with the NAS, we recommend to get an hard drive that are listed on the HCL for your readynas device.
Please note: NETGEAR Support can and will deny support on devices using drives not found on the official compatibility list.
Marty_M
TomBlack
Sep 11, 2017Guide
I understand this drive is not on the HCL List, but it has the same interface as a IronWolf Pro ST10000NE0004, thus the question. The difference is 2Tb in space plus the 0086 drive is an Enterprise Level Drive with almost twice the MTBF Rating.
There is also the question of 512e vs. 4Kn Interfaces. The HCL lists both of these interfaces for 8Tb Seagates, but nothing for 10 & 12 Tb drives. I have seen other threads stateing the NAS can handle these drives as well.
If this is true about 10 & 12 TB drives, if the NAS can handle both 512e & 4Kn 8Tb drives, why couldn't it also handle 512e & 4Kn 10Tb drives?
I am leaning toward Enterprise Level drives because they are more robust. Am currently running 6 x ST4000VN0001s which are Enterprise NAS Drives. So again, Enterprise Level drives should also work as long as they have compatible 512e & 4Kn interfaces.
It strikes me that Netgear has not updated the HCL for these newer drives. The latest Seagate 12Tb drive has a dual 512e & 4Kn Interface, but there are no 12Tb drives listed on the HCL, which tells me that Netgear just has not updated the HCL.
So I guess the main questions are: Is the NAS running Firmware 6.8.0 limited in the size of the drive AND is the NAS compatible with both 512e & 4Kn Interfaces?
Would also appreciate getting me in contact with your engineering to discuss these questions.
Thanks for your help and support!
