TomBlack
Sep 06, 2017Guide
SEAGATE ST10000NM0086 Drives
Want to confirm that Seagate's ST10000NM0086 Drive is compatible with a 51600 or a 626X or a 628X NAS. TIA!
- Sep 12, 2017
Hello TomBlack,
The drives that are listed on the HCL gone through testing and proved that work fine with the NAS. As for when the HCL will be updated we have not receive any notification yet from the department that handle it. For now we recommend to get the one's that are listed on the HCL.
Marty_M
NETGEAR Community Team
Marty_M
Sep 11, 2017NETGEAR Employee Retired
Hello TomBlack,
Seagate's ST10000NM0086 is not listed as compatible hard drive under HCL of the NAS. There are 10 TB hard drives that are listed that is compatible with the NAS, we recommend to get an hard drive that are listed on the HCL for your readynas device.
Please note: NETGEAR Support can and will deny support on devices using drives not found on the official compatibility list.
Marty_M
Marty_M
Sep 12, 2017NETGEAR Employee Retired
Hello TomBlack,
Marty_M
- StephenBSep 12, 2017Guru - Experienced User
I get that this is a frustrating response, because the enterprise-class drive you want to use is almost certainly compatibile.
But unfortunately that is Netgear's positon on the HCL.
- TomBlackSep 12, 2017Guide
Yeah, very frustrating. Finally talked to an engineer in Salt Lake yesterday who was very, very knowledgeable. I settled on the Seagate ST10000NM0146 Enterprise 10TB in the 4Kn Interface.
Thanks
