TomBlack
Sep 06, 2017Guide
SEAGATE ST10000NM0086 Drives
Want to confirm that Seagate's ST10000NM0086 Drive is compatible with a 51600 or a 626X or a 628X NAS. TIA!
- Sep 12, 2017
Hello TomBlack,
The drives that are listed on the HCL gone through testing and proved that work fine with the NAS. As for when the HCL will be updated we have not receive any notification yet from the department that handle it. For now we recommend to get the one's that are listed on the HCL.
Marty_M
NETGEAR Community Team
Marty_M
Sep 12, 2017NETGEAR Employee Retired
Hello TomBlack,
Marty_M
Sep 12, 2017Guru - Experienced User
I get that this is a frustrating response, because the enterprise-class drive you want to use is almost certainly compatibile.
But unfortunately that is Netgear's positon on the HCL.
