CrippleZero
Jun 13, 2022Aspirant
Sessions Stuck Open?
I am using a ReadyNAS 3138 device. I have 2x 10TB Ironwolf drives (mirrored) and an attached 6TB WD My Book drive. The external is in place until I can afford to slide in another 10TB drive to hori...
Jun 14, 2022Guru - Experienced User
Try entering this from CMD on the PC:
net use * /delete /y
Then attempt to access the USB share using the NAS IP address - entering
\\nas-ip-address\sharename
into the windows explorer address bar. Use the real IP address and share name of course, and be careful to enter the correct slash. If you use the wrong one, it will open your browser.
