ICT_Team
Sep 09, 2015Aspirant
Shares Empty When Viewing Via FTP Connection in FileZila
Hi All I have been trying to setup FTP access to the first of our NAS units and it's not working. I can connect to the NAS and I see the 3 shares that are on the NAS as folders, but when I try an...
- Sep 16, 2015
Tried an OS Re-install on the unit but it didn't resolve the "The share operation failed 1002030001" error
Backed up the data on the NAS and did a factory defaults re-set. After setting up the unit the "The share operation failed 1002030001" error was no longer happening when changing the share access settings.
Now that I could change the settings I have fixed the access rights and I can upload and download to all my shares via FTP.
turnerpunk
Sep 10, 2015Aspirant
I'm not sure if your version is the same as mine, but check out each individual share. Along with the network access options, there is also a section for File access on mine. Check the security settings there and make sure nothing is awry! Hope that helps!
