SliceTheAir
Oct 07, 2014Aspirant
Shares suddanly not available anymore
Hi, I am using my readynas Duo(v1) for 4 years now and are a satisfied customer :) Now last wek some trouble occured. Timeline: I use the nas up to last week with several shares, CIFS enabled...
SliceTheAir
Oct 08, 2014Aspirant
Hi,
No I don't have a 2Tb available.
Please can you explian?
1) I thought, maybe wrong, that the disk are mirrored so an exact copy of each other. So pulling one of the disks (same as one failing) is never a problem?
2) If I had a 2Tb available (like I buy one now) ho can I create the clone from an array to a single disk when frontview, but also Kitty does not work anymore?
Is it advisable to reboort the nas in the hope I can connect kitty again and backup the last bit of data (to a small local USB device)?? Ik know exactly which directories I need in order to heva a complete set together with the data my brother has on his NAS as a backup of mine.
Regards
mark
Regards
mark
