SliceTheAir
Oct 07, 2014Aspirant
Shares suddanly not available anymore
Hi, I am using my readynas Duo(v1) for 4 years now and are a satisfied customer :) Now last wek some trouble occured. Timeline: I use the nas up to last week with several shares, CIFS enabled...
mdgm-ntgr
Oct 08, 2014NETGEAR Employee Retired
A factory reset is the way to go. The problem is not with 4.1.13, it is with your array or with the disks.
Can you send me your logs after you have done a factory default with your disks and restored your data from backup?
