The_Old_Fart
Nov 07, 2012Follower
Simple Question. Duo to sony & panosonic
Hi Guys, Netgear ReadyNAS Duo 2-Bay Can this NAS be used to stream to Sony BDP-S390 Blu-ray player, and a Panasonic TV, without the need to resort to transcoding? Edit: can Twonkey be ...
LowIQ
Nov 22, 2012Aspirant
I have a ReadyNAS Ultra6, I got a Sony BDP-S390. Worked great for one night, I was able to stream .mkv and .mp4 without a problem. Then i upgraded the firmware on the BDP to v M11.R.0422 (they force you to if you want to use Amazon Instant Video or Netflix) and now every video I try and play says "The File is corrupt or not supported". Sony always forces you to upgrade, i knew this and thought twice about purchasing it, i should have avoided the Sony. Also the updates take forever, had to try 3 times and ultimately left it over night to complete.
