PhillHopkins74
Sep 04, 2013Aspirant
Simple ReadyNAS to Drobo backup
Hi, I have a 2120 accessing Front view through a W7 Pro (64bit) desktop. I'm trying to set up a backup from a local share on the ReadyNAS to my Drobo NAS using the remote Windows / NAS timestamp metho...
Sep 05, 2013Guru - Experienced User
The help on my Pro says:
Though if the Drobo is set to allow NFS or Rsync access to the share, those might be better protocols.
Is that what you tried?
Sample paths for different protocols:
Windows PC
If the URI is: \\myserver\myshare\myfolder
The host is: //myserver
The path is: myshare/myfolder
Note the direction of the slashes in the above example.
