gdeguillebon
Sep 16, 2017Star
Since Google Drive is enable, Disk spin-down does not work anymore
Hello, Since Google Drive sync is enabled on my readynas (RN314), the spin-down does not work anymore. After disable the sync, the spin-down is working again Did you experiment that ? the prob...
- Oct 09, 2017
The reponse from Netgear support team !
I just got a return from our engineers. Unfortunately the spin-down is not meant to be used with a cloud application. This one uses a service that will constantly check for updates. It may be put in the future an option to create a programming, but for now it is not yet planned.
Marty_M
Sep 21, 2017NETGEAR Employee Retired
Hello gdeguillebon,
It does appear that there is somewhat conflict between the Google Drive and Disk spindown on your NAS. I have tried to simulate the concern in our laboratory and I did not encounter the problem, I was able to enable both feature at the same time. What firmware is your NAS running at? Have you tried reflashing or upgrading the firmware?
Marty_M
NETGEAR Community Team
gdeguillebon
Sep 21, 2017Star
Hello Marty,
Thanks to look my problem.
my firmware is ReadyNASOS 6.8.0.
do you need some others logs file
Best
