gdeguillebon
Sep 16, 2017Star
Since Google Drive is enable, Disk spin-down does not work anymore
Hello, Since Google Drive sync is enabled on my readynas (RN314), the spin-down does not work anymore. After disable the sync, the spin-down is working again Did you experiment that ? the prob...
- Oct 09, 2017
The reponse from Netgear support team !
I just got a return from our engineers. Unfortunately the spin-down is not meant to be used with a cloud application. This one uses a service that will constantly check for updates. It may be put in the future an option to create a programming, but for now it is not yet planned.
Marty_M
Sep 21, 2017NETGEAR Employee Retired
Hello gdeguillebon,
It does appear that there is somewhat conflict between the Google Drive and Disk spindown on your NAS. I have tried to simulate the concern in our laboratory and I did not encounter the problem, I was able to enable both feature at the same time. What firmware is your NAS running at? Have you tried reflashing or upgrading the firmware?
Marty_M
NETGEAR Community Team
Marty_M
Hello gdeguillebon,
Have you tried reflashing the firmware? You may also want to try the beta firmware 6.8.1 or 6.9.0 and check if it will make any difference. I would recommend to have a back of the data save on the NAS before further troubleshooting.
Marty_M
- gdeguillebonSep 21, 2017Star
Hi Marty,
I have this problem since the Google Drive sync feature is available (6.7.1), I flashed all intermediat version but the problem still persist.
I am not very confortable to flash beta firmware if I can't rollback the firmware in case of regression..
By the past my spindown never worked, so I updated some hdparm parameters to disable auto spindown by devices.
Best
- Marty_MSep 26, 2017NETGEAR Employee Retired
Hello gdeguillebon,
Official firmware version of 6.8.1 is now available for download, you may want to try to upgrade the firmware and check if that will help with the concern.
Marty_M
NETGEAR Community Team- gdeguillebonSep 26, 2017Star
Hello,
Today I tried the 6.8.1
I deleted the Google Drive folder, then it was recreated with the sync
The problem still persist... when I stop Google Drive sync, the drives go to spindown without any problem 5 min later
below the google-drive and spindown logs
~$ sudo journalctl -u google-drive -u noflushd --since "2017-09-26 18:00:00"
-- Logs begin at Sat 2017-07-29 04:43:16 CEST, end at Tue 2017-09-26 19:02:15 CEST. -- Sep 26 18:00:17 READYNAS systemd[1]: Started Google Drive client for ReadyNAS. Sep 26 18:00:17 READYNAS ng-csd[11933]: Reset the cache. SQL Statement invalid: SQL error or missing database: no such table: settings Sep 26 18:00:17 READYNAS ng-csd[11933]: W0926 18:00:17.175423 11933 FSCache.cpp:78] Reset the cache. SQL Statement invalid: SQL error or missing database: no such table: settings Sep 26 18:02:26 READYNAS ng-csd[11933]: Failed to parse GoogleDrive error response. Sep 26 18:02:26 READYNAS ng-csd[11933]: E0926 18:02:26.112316 11949 GoogleDriveErrorMarshaller.cpp:115] Failed to parse GoogleDrive error response. Sep 26 18:02:26 READYNAS ng-csd[11933]: E0926 18:02:26.112509 11949 GoogleDriveIOClient.cpp:283] Failed to download file. error: Failed to parse GoogleDrive error response. Sep 26 18:02:26 READYNAS ng-csd[11933]: E0926 18:02:26.112948 11949 GoogleDriveFS.cpp:265] Failed to fetch file. node = Node metadata: { id = 19NADJRbs9Lc3LqjU3Pq9Wn4PCl9vljnk9Q, isFolder = 0, isTrashed = 0, name = 20130719_163801. jpg, localName = 20130719_163801.jpg, path = /Google Photos/20130719_163801.jpg, mimeType = image/jpeg, size = 2630068, createdTime = 2013-07-19T14:38:01.000000Z, modifiedTime = 2015-06-21T22:10:31.000000Z, checksum = 3e9963595d0a8 712917cb62307bc23fc, parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY }path = /data/Drive_gdg/.1506441591/._ngcloudignore_download/499a52a39e4bcc8c21bb589cf354d69f Sep 26 18:02:26 READYNAS ng-csd[11933]: E0926 18:02:26.113067 11949 SyncDownsyncFile.cpp:299] Failed to download node. node = Node metadata: { id = 19NADJRbs9Lc3LqjU3Pq9Wn4PCl9vljnk9Q, isFolder = 0, isTrashed = 0, name = 20130719_1 63801.jpg, localName = 20130719_163801.jpg, path = /Google Photos/20130719_163801.jpg, mimeType = image/jpeg, size = 2630068, createdTime = 2013-07-19T14:38:01.000000Z, modifiedTime = 2015-06-21T22:10:31.000000Z, checksum = 3e99635 95d0a8712917cb62307bc23fc, parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY }, _nodeLocalPath = /data/Drive_gdg/Google Photos/20130719_163801.jpg Sep 26 18:02:26 READYNAS ng-csd[11933]: Failed to download file. error: Failed to parse GoogleDrive error response. Sep 26 18:02:26 READYNAS ng-csd[11933]: Failed to fetch file. node = Node metadata: { id = 19NADJRbs9Lc3LqjU3Pq9Wn4PCl9vljnk9Q, isFolder = 0, isTrashed = 0, name = 20130719_163801.jpg, localName = 20130719_163801.jpg, path = /Google Photos/20130719_163801.jpg, mimeType = image/jpeg, size = 2630068, createdTime = 2013-07-19T14:38:01.000000Z, modifiedTime = 2015-06-21T22:10:31.000000Z, checksum = 3e9963595d0a8712917cb62307bc23fc, parentId = 1RfZ5qgh1Jd 0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY }path = /data/Drive_gdg/.1506441591/._ngcloudignore_download/499a52a39e4bcc8c21bb589cf354d69f Sep 26 18:02:26 READYNAS ng-csd[11933]: Failed to download node. node = Node metadata: { id = 19NADJRbs9Lc3LqjU3Pq9Wn4PCl9vljnk9Q, isFolder = 0, isTrashed = 0, name = 20130719_163801.jpg, localName = 20130719_163801.jpg, pa th = /Google Photos/20130719_163801.jpg, mimeType = image/jpeg, size = 2630068, createdTime = 2013-07-19T14:38:01.000000Z, modifiedTime = 2015-06-21T22:10:31.000000Z, checksum = 3e9963595d0a8712917cb62307bc23fc, parentId = 1RfZ5qgh 1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY }, _nodeLocalPath = /data/Drive_gdg/Google Photos/20130719_163801.jpg Sep 26 18:03:12 READYNAS ng-csd[11933]: Failed to parse GoogleDrive error response. Sep 26 18:03:12 READYNAS ng-csd[11933]: E0926 18:03:12.270489 11953 GoogleDriveErrorMarshaller.cpp:115] Failed to parse GoogleDrive error response. Sep 26 18:03:12 READYNAS ng-csd[11933]: Failed to download file. error: Failed to parse GoogleDrive error response. Sep 26 18:03:12 READYNAS ng-csd[11933]: E0926 18:03:12.272727 11953 GoogleDriveIOClient.cpp:283] Failed to download file. error: Failed to parse GoogleDrive error response. Sep 26 18:03:12 READYNAS ng-csd[11933]: Failed to fetch file. node = Node metadata: { id = 1vWlxh1Wy4j-eljeIijfFCrPb7aoc_0uKyg, isFolder = 0, isTrashed = 0, name = 20140416_105022.jpg, localName = 20140416_105022.jpg, path = /Google Photos/20140416_105022.jpg, mimeType = image/jpeg, size = 2337527, createdTime = 2014-04-16T08:50:21.000000Z, modifiedTime = 2015-06-21T22:28:55.000000Z, checksum = 39f03906281ca71389d8c258f7488ac1, parentId = 1RfZ5qgh1Jd 0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY }path = /data/Drive_gdg/.1506441591/._ngcloudignore_download/7c29de2e059991c594e4b8e40c4727d5 Sep 26 18:03:12 READYNAS ng-csd[11933]: E0926 18:03:12.275022 11953 GoogleDriveFS.cpp:265] Failed to fetch file. node = Node metadata: { id = 1vWlxh1Wy4j-eljeIijfFCrPb7aoc_0uKyg, isFolder = 0, isTrashed = 0, name = 20140416_105022. jpg, localName = 20140416_105022.jpg, path = /Google Photos/20140416_105022.jpg, mimeType = image/jpeg, size = 2337527, createdTime = 2014-04-16T08:50:21.000000Z, modifiedTime = 2015-06-21T22:28:55.000000Z, checksum = 39f03906281ca 71389d8c258f7488ac1, parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY }path = /data/Drive_gdg/.1506441591/._ngcloudignore_download/7c29de2e059991c594e4b8e40c4727d5 Sep 26 18:03:12 READYNAS ng-csd[11933]: Failed to download node. node = Node metadata: { id = 1vWlxh1Wy4j-eljeIijfFCrPb7aoc_0uKyg, isFolder = 0, isTrashed = 0, name = 20140416_105022.jpg, localName = 20140416_105022.jpg, pa th = /Google Photos/20140416_105022.jpg, mimeType = image/jpeg, size = 2337527, createdTime = 2014-04-16T08:50:21.000000Z, modifiedTime = 2015-06-21T22:28:55.000000Z, checksum = 39f03906281ca71389d8c258f7488ac1, parentId = 1RfZ5qgh 1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY }, _nodeLocalPath = /data/Drive_gdg/Google Photos/20140416_105022.jpg Sep 26 18:03:12 READYNAS ng-csd[11933]: E0926 18:03:12.277231 11953 SyncDownsyncFile.cpp:299] Failed to download node. node = Node metadata: { id = 1vWlxh1Wy4j-eljeIijfFCrPb7aoc_0uKyg, isFolder = 0, isTrashed = 0, name = 20140416_1 05022.jpg, localName = 20140416_105022.jpg, path = /Google Photos/20140416_105022.jpg, mimeType = image/jpeg, size = 2337527, createdTime = 2014-04-16T08:50:21.000000Z, modifiedTime = 2015-06-21T22:28:55.000000Z, checksum = 39f0390 6281ca71389d8c258f7488ac1, parentId = 1RfZ5qgh1Jd0MRqnLVjMP2DKBpcl_YcsYqG8nGXoO2bY }, _nodeLocalPath = /data/Drive_gdg/Google Photos/20140416_105022.jpg Sep 26 18:05:45 READYNAS ng-csd[11933]: Failed to parse GoogleDrive error response. Sep 26 18:05:45 READYNAS ng-csd[11933]: Request failed, now waiting 672 ms before attempting again. Sep 26 18:05:46 READYNAS ng-csd[11933]: E0926 18:05:45.961922 11951 GoogleDriveErrorMarshaller.cpp:115] Failed to parse GoogleDrive error response. Sep 26 18:05:46 READYNAS ng-csd[11933]: W0926 18:05:45.962118 11951 WSClient.cpp:128] Request failed, now waiting 672 ms before attempting again. Sep 26 18:06:13 READYNAS ng-csd[11933]: Failed to parse GoogleDrive error response. Sep 26 18:06:13 READYNAS ng-csd[11933]: Request failed, now waiting 0 ms before attempting again. Sep 26 18:06:13 READYNAS ng-csd[11933]: E0926 18:06:13.381319 11951 GoogleDriveErrorMarshaller.cpp:115] Failed to parse GoogleDrive error response. Sep 26 18:06:13 READYNAS ng-csd[11933]: W0926 18:06:13.381587 11951 WSClient.cpp:128] Request failed, now waiting 0 ms before attempting again. Sep 26 18:06:38 READYNAS ng-csd[11933]: Failed to parse GoogleDrive error response. Sep 26 18:06:38 READYNAS ng-csd[11933]: E0926 18:06:38.846272 11951 GoogleDriveErrorMarshaller.cpp:115] Failed to parse GoogleDrive error response. Sep 26 18:06:38 READYNAS ng-csd[11933]: W0926 18:06:38.846973 11951 WSClient.cpp:128] Request failed, now waiting 1000 ms before attempting again. Sep 26 18:06:38 READYNAS ng-csd[11933]: Request failed, now waiting 1000 ms before attempting again. Sep 26 18:28:29 READYNAS systemd[1]: Stopping Google Drive client for ReadyNAS... Sep 26 18:28:29 READYNAS systemd[1]: Stopped Google Drive client for ReadyNAS. Sep 26 18:33:34 READYNAS noflushd[9502]: Spinning down disk 2 (/dev/sdb). Sep 26 18:34:07 READYNAS noflushd[9502]: Spinning down disk 1 (/dev/sda). Sep 26 18:34:09 READYNAS noflushd[9502]: Spinning down disk 3 (/dev/sdc). Sep 26 18:36:07 READYNAS noflushd[9502]: Spinning up disk 1 (/dev/sda) after 0:01:58. Sep 26 18:36:07 READYNAS noflushd[9502]: Spinning up disk 2 (/dev/sdb) after 0:02:30. Sep 26 18:38:37 READYNAS noflushd[9502]: Spinning down disk 4 (/dev/sdd). Sep 26 18:41:09 READYNAS noflushd[9502]: Spinning down disk 1 (/dev/sda). Sep 26 18:41:12 READYNAS noflushd[9502]: Spinning down disk 2 (/dev/sdb). Sep 26 18:53:04 READYNAS noflushd[9502]: Spinning up disk 1 (/dev/sda) after 0:11:52. Sep 26 18:53:04 READYNAS noflushd[9502]: Spinning up disk 2 (/dev/sdb) after 0:11:50. Sep 26 18:53:09 READYNAS noflushd[9502]: Spinning up disk 3 (/dev/sdc) after 0:18:57. Sep 26 18:53:09 READYNAS noflushd[9502]: Spinning up disk 4 (/dev/sdd) after 0:14:30. Sep 26 18:58:29 READYNAS noflushd[9502]: Spinning down disk 2 (/dev/sdb). Sep 26 18:58:32 READYNAS noflushd[9502]: Spinning down disk 3 (/dev/sdc). Sep 26 18:58:34 READYNAS noflushd[9502]: Spinning down disk 4 (/dev/sdd). Sep 26 18:58:52 READYNAS noflushd[9502]: Spinning down disk 1 (/dev/sda). Sep 26 19:01:39 READYNAS noflushd[9502]: Spinning up disk 1 (/dev/sda) after 0:02:45.Thanks for your help
- Marty_MSep 24, 2017NETGEAR Employee Retired
Hello gdeguillebon,
I believe you have an option to roll back to the latest official firmware version if in case the beta firmware did not address the concern.
Marty_M
my concern was about this WARNINGS:
- Devices updated with 6.9.0 firmware should not be downgraded to earlier firmware versions.
So if you can confirm that there are not effects to rollback, ok I will perform the update otherwise I will wait the official.
Best
