gdeguillebon
Sep 16, 2017Star
Since Google Drive is enable, Disk spin-down does not work anymore
Hello, Since Google Drive sync is enabled on my readynas (RN314), the spin-down does not work anymore. After disable the sync, the spin-down is working again Did you experiment that ? the prob...
- Oct 09, 2017
The reponse from Netgear support team !
I just got a return from our engineers. Unfortunately the spin-down is not meant to be used with a cloud application. This one uses a service that will constantly check for updates. It may be put in the future an option to create a programming, but for now it is not yet planned.
Marty_M
Sep 21, 2017NETGEAR Employee Retired
Hello gdeguillebon,
Have you tried reflashing the firmware? You may also want to try the beta firmware 6.8.1 or 6.9.0 and check if it will make any difference. I would recommend to have a back of the data save on the NAS before further troubleshooting.
Marty_M
NETGEAR Community Team
Marty_M
Sep 24, 2017NETGEAR Employee Retired
Hello gdeguillebon,
I believe you have an option to roll back to the latest official firmware version if in case the beta firmware did not address the concern.
Marty_M
- gdeguillebonSep 26, 2017Star
my concern was about this WARNINGS:
- Devices updated with 6.9.0 firmware should not be downgraded to earlier firmware versions.
So if you can confirm that there are not effects to rollback, ok I will perform the update otherwise I will wait the official.
Best
