gdeguillebon
Sep 16, 2017Star
Since Google Drive is enable, Disk spin-down does not work anymore
Hello, Since Google Drive sync is enabled on my readynas (RN314), the spin-down does not work anymore. After disable the sync, the spin-down is working again Did you experiment that ? the prob...
- Oct 09, 2017
The reponse from Netgear support team !
I just got a return from our engineers. Unfortunately the spin-down is not meant to be used with a cloud application. This one uses a service that will constantly check for updates. It may be put in the future an option to create a programming, but for now it is not yet planned.
gdeguillebon
Oct 02, 2017Star
The reponse from support team !
I was able to reproduce the symptoms that you currently have with your NAS. I will inform my engineers for a resolution. I will keep you informed of the progress of your file.
gdeguillebon
Oct 09, 2017Star
- StephenBOct 09, 2017Guru - Experienced User
Put this on the idea exchange - if lots of people vote for it, it is more likely to be implemented.
