ReadyEye
Mar 15, 2013Follower
Slot Failure - Can I reuse drive?
I have a ReadyNAS 3200 with 4x1TB drives installed in a RAID-5. I got a warning that a drive was bad. I took out the bad drive and substituted a new one. After a while, the new drive also showed as...
Mar 16, 2013Guru - Experienced User
Delete the volumes on a PC, and then there is no possibility of confusion.
