namco
Mar 24, 2012Aspirant
Slow "internal" transfers [duo v2]
I just bought the Duo 2 and struggle with extremly slow transfers. I use transmission to download files to c/media easily, but when I want to move the files around to different folders I only get 3-4m...
jeapie38
Mar 29, 2012Tutor
mdgm wrote: If you are moving a file within a share then it'll move instantly. If you move it between shares then it'll have to copy to your PC then back to the NAS again.
First, copy & Paste between shares isn't possible on http or web mode, only on CIFS or windows mode.
Secondly, move of files within a share is instantaneous only on web mode (no transit via PC), not on windows, but 1Mb/s isn't normal : Technical Support is looking at system logs.
- Jan 21, 2017Retired_Member
