cmchoi's avatar
cmchoi
SLOW RAID Level X-RAID2, 6 disks (with dual redundancy)
I have a Pro 6, I create volume with 5 disks (3TB each). After sync completed, I added 6th disk as dual redundancy.
It is very slow to restrip after 6th disk is added. Is this normal? It will take more than 10 day!!!!!!
Configuration: RAID Level X-RAID2, 6 disks (with dual redundancy)
Status: Restriping 1% complete, Time to finish 276 hr 8 min, Speed 2891 KB/sec
RAID Disks:
Ch 1 : Seagate ST33000651AS [2794 GB]
2790 GB allocated
Ch 2 : Seagate ST33000651AS [2794 GB]
2790 GB allocated
Ch 3 : Seagate ST33000651AS [2794 GB]
2790 GB allocated
Ch 4 : Seagate ST33000651AS [2794 GB]
2790 GB allocated
Ch 5 : Seagate ST33000651AS [2794 GB]
2790 GB allocated
Ch 6 : Seagate ST3000DM001-9YN166 [2794 GB]
  • StephenB's avatar
    I have the LAG type set to LACP in the switch (GS724T in my case); you also have to put the two switch ports into the group.
    On the NAS I have LACP with xmit hash policy of layer 2 + layer 3.
    I don't believe the order matters, my recollection is that both devices fail over to non-teamed operation if the LACP setup fails.
ProSupport for Business
