xlr8r
Sep 19, 2013Luminary
slow transfer speed between 2 Nas 11mb/sec ?
I have an RNDP4000 and a RNDP6000 i wanted to move all the data from the RNDP4000 so that i could set it up again with XRAID-2 (currently raid0) when i try to transfer files to the RNDP6000 from...
mdgm-ntgr
Sep 19, 2013NETGEAR Employee Retired
Are you using a backup job to copy the data direct between the two devices or copying the data via your PC? I would recommend using Frontview backup jobs. Use NFS for full backups and then change the backup job properties to use Rsync for incremental backup jobs.
How is your PC connected to the network?
Have you verified the NAS is connected to a gigabit router/switch? Your speeds sound like speeds you'd get using a 100mbit router.
