xlr8r
Sep 19, 2013Luminary
slow transfer speed between 2 Nas 11mb/sec ?
I have an RNDP4000 and a RNDP6000 i wanted to move all the data from the RNDP4000 so that i could set it up again with XRAID-2 (currently raid0) when i try to transfer files to the RNDP6000 from...
xlr8r
mdgm wrote: Are you using a backup job to copy the data direct between the two devices or copying the data via your PC? I would recommend using Frontview backup jobs. Use NFS for full backups and then change the backup job properties to use Rsync for incremental backup jobs.
How is your PC connected to the network?
Have you verified the NAS is connected to a gigabit router/switch? Your speeds sound like speeds you'd get using a 100mbit router.
hi
im just using my computer by opening the 2 drives (mapped network drives) and just teracopying from one folder to the other. Normally when i copy files from just my pc to a NAS , i get around 70mb/sec but between NAS's its 11mb/sec
All routers and switches are gigabit.
