Scubbie
May 29, 2015Apprentice
Slow transfer with RN104
Hi there, I've been trying to help a friend set up a ReadyNAS 104 and we are experiencing a couple of problems. I have a ReadyNAS Ultra 6 Plus and the way of setting up the RN104 is quite different...
Scubbie
Jun 01, 2015Apprentice
Ok, the NAS is back to RAID 5, with X-RAID lit as green.
The capacity is now 10.9 TB, which is fine.
However the transfer rate is terrible once more - about 10.8MiB/s.
Having wiped the unit, there are currently no other apps installed.
Cables have been swapped around. The Switch and router both report that the NAS is connected at 1Gbit.
The computer can move files to/from another NAS without any major issues and achieves in the region of 70-80MiB/s with the same computer.
Do you have any suggestions as to why the transfer rate is so bad?
