kalpsr's avatar
kalpsr
Snapshot use place on RN104 but no snapshot in timeline
As shown in below images i have situcation like this.
I have already ran 'Balance' and also upgraded the Fw.
Also ran commands :
# touch /.force_snapshots_upgrade
# systemctl restart readynasd
but no sucsess.
Can anyone help about it?
  • Try to check snapshots by command
    btrfs subvolume list -R /data | grep snapshot
    you should get something like this
    root@rn312:~# btrfs subvolume list -R /data | grep snapshot
    ID 294 gen 432570 top level 264 received_uuid - path ._share/Transmission/.snapshot/c_1430038837
    ID 295 gen 432570 top level 265 received_uuid - path Transmission/.snapshots
    ID 319 gen 442166 top level 318 received_uuid - path btsync/.snapshots
    ID 321 gen 432570 top level 263 received_uuid - path Backup/.snapshots
    ID 324 gen 432570 top level 262 received_uuid - path Documents/.snapshots
    ID 326 gen 432570 top level 261 received_uuid - path Music/.snapshots
    ID 328 gen 432570 top level 259 received_uuid - path Pictures/.snapshots
    ID 331 gen 432570 top level 260 received_uuid - path Videos/.snapshots
    ID 438 gen 442144 top level 437 received_uuid - path rsyslog/.snapshots
    you can delete snapshot in bold above (for example) using this one
     btrfs subvolume delete '/data/._share/Transmission/.snapshot/c_1430038837'
    • kalpsr's avatar
      kalpsr
      Thanks very muchsotrack.
      It worked like a charm.
      I am able to delete the snapshots using commands given by you.
      Thank you very much for your support.
      • FramerV's avatar
        FramerV
        NETGEAR Employee Retired
        Hi kalpsr,
        If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
        The Netgear community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
