DRI
Dec 21, 2015Aspirant
Snapshot use place on RN316 but no snapshot in timeline
Hello,
I have a space problem on my RN316 (FW 6.4.1).
I have no snpashot in timeline but i see snapshot use a lots of space on my RN316.
Some manipluation to delete them and get back my disk space ?
Can someone help me ?
Thanks a lot.
The snapshot upgrade has completed so you should be able to see your snapshots to delete them if you want.
I think the newest one is from back in June this year.
Once you have deleted the snapshots you wish to delete and have got volume usage below 80% I would suggest you run a balance. I would also suggest then setting up a schedule to run defrags and balances to run weekly.
Usually there is a list of shared folders on the left side of that screen. Did you create shares on the NAS?
If so, are you looking in every share? Do you see any snapshot counts under the share folders on the left pane?
- DRIAspirant
Hello,
Thanks for your reply. I have some share active on the RN316 and nobody has snapshot.
- mdgm-ntgrNETGEAR Employee Retired
If you like if StephenB's suggestion does not resolve it, please send your logs in (see the Sending Logs link in my sig).
- DRIAspirant
Hello,
I have send you the logs extract for our RN316.
