XtheUnknown
May 14, 2019Apprentice
Snapshots not being taken as specified on 6.10.0 HF2
Greetings!
I have a number of shares with various snapshot settings, which are not being actioned as specified:
With "smart" management set to daily, snapshots are only being taken weekly.
May 14, 2019Guru - Experienced User
XtheUnknown wrote:
With "custom" manangement and "only take snapshots with changes" set ON and a midnight daily schedule set, snapshots only being taken occasionally.
This is my config, and it appears to be working correctly. I'll keep an eye on it though, and let you know if I see anything off.
- XtheUnknownMay 15, 2019Apprentice
Thanks.
Smart daily snapshots missed again overnight as were the custom midnight only-with-changes snapshots.
Custom hourly snapshots (only-with-changes) are being taken once daily at 2am (even if no files have changed).
So both the temporal scheduling and the detection of changes appears suspect.
- BingkeXMay 15, 2019NETGEAR Expert
XtheUnknown wrote:
Thanks.
Hi XtheUnknown
Would you please check the timezone of your readyNas on System->Overview->Device time, settings page? And all your issued items are shares? not Home folder or iscsi LUN?
Best Regards.
Hi BingkeX,
The "2am" issue is on the home folder share, the other issues are on normal shares, there are no iSCSI LUNs.
Only *some* users have protection (ie snapshots) enabled on their home folders.
My timezone is set to Western European (GMT-0) - but we're currently on daylight saving/summer time, therefore the actual local time is equivalent to GMT+1 (and appears to be curretly reported by the NAS as such).
Hope that helps. BTW, I can't be sure, but I think this behaviour may have started after one or both of the hotfixes was applied.
