tjsnow
Mar 25, 2016Aspirant
Snapshots using 1tb of storage on 314, but none in timeline
I currently show that ove 1TB of storageis being used by snapshots, however no snapshots show up on my timeline. I am trying to clear these out, becuse I don't even use snapshots any more. I have loo...
- Apr 12, 2016
I have deleted the snapshot and the expected space has been freed up.
I would suggest keeping volume usage to 80-85% or less and scheduling a weekly balance.
You may also want to schedule a defrag.
Scheduled volume maintenance should be scheduled to run at a time when you are not using the NAS much.
mdgm-ntgr
Mar 28, 2016NETGEAR Employee Retired
If you still have space used by snapshots after following JennC's suggestion please send in your logs (see the Sending Logs link in my sig).
tjsnow
Apr 12, 2016Aspirant
Ok I have looked at all the solutions I can find. I am now going to include scren shots, hopefully this will help.
My System Storage showing that over 1tb is wasted on snapshots:
Data page showing that there are 0 (zero) snapshots:
When I try to delete using the recovery option, it too show that there are no snapshots (checked every folder):
I am not sure what else to do. So MDGM, I have sent my logs in with a link.
Thanks...
