abruz's avatar
abruz
Snapshots using 500GB but never turned on.....why? (And how to recover the space)
GUI showing 500GB of space being used by Snapshots (and it grows every day).  I do not have snapshots turned on, have never had them turned on (to my knowledge), and cannot find any snapshots in the ...
  • StephenB's avatar
    Feb 06, 2018
    wrote:
    I tried the "btrfs subvolume delete /data/BayBlueprint/.snapshots" but it gave me an error:
    ERROR:  cannot delete .......Directory not empty
    I'll need to figure out if I can force a delete or recursively delete.
    Each folder in /data/BayBlueprint/.snapshots is a subvolume, so I guess you do need to delete those.  Try deleting one of them - for instance btrfs subvolume delete /data/BayBlueprint/.snapshots/5/snapshot
    There is no recursive delete option, though I guess you could try to build a script.  If you don't have too many, it's probably easiest to just change the /5/ to another snapshot index and redoing the command.
ProSupport for Business
