nmgeek's avatar
nmgeek
Tutor
Mar 03, 2019
Solid red alert LED, no network link, flashing red disk light
It has the latest ReadyNAS firmware.  One disk started complaining about SMART errors but continued to function (while likely reducing performance).  I bought a replacement drive but the drive was ba...
  • nmgeek's avatar
    nmgeek
    Mar 06, 2019
    My bad.  The ethernet cable was loose.  When I fixed that I got a link light and found the unit at its usual IP address.  (I was expecting the worst so I didn't check the basic stuff like "is it plugged in?")
    And I am being really stupid because the model of disk I bought nearly matches the netgear compatibility list except that it is SAS.
    Sorry to waste your time!
ProSupport for Business
