mjw1
Sep 03, 2010Aspirant
[SOLVED] NTFS Operation Not Supported (45)
[PLEASE JUMP HERE IF YOU WANT TO GO STRAIGHT TO THE SOLUTION] I have been struggling with a few permissions related problems and would really appreciate some help: This is my setup: - User mode...
ewok
Sep 07, 2010NETGEAR Expert
Some programs will save a file to a temp file, delete the original, then rename the temp file when saving over a file. This would cause the saved over file to be owned by the last user to edit the file.
I'm not sure what would cause 2 and 3. Does this happen with other programs, for example Notepad?
