mjw1
Sep 03, 2010Aspirant
[SOLVED] NTFS Operation Not Supported (45)
[PLEASE JUMP HERE IF YOU WANT TO GO STRAIGHT TO THE SOLUTION] I have been struggling with a few permissions related problems and would really appreciate some help: This is my setup: - User mode...
ewok
Sep 13, 2010NETGEAR Expert
mjw wrote:
Is there any way that Netgear could please attempt to reproduce and then fix the bug? Perhaps someone could see if this problem can be reproduced on the latest x86 RAIDiator firmware (since perhaps this contains a more recent version of the ntfs-3g package according to http://www.readynas.com/?p=3728). If it works on x86, then there is some hope that applying the same update to Sparc will fix the bug. I would help, but I don't own an x86 Readynas.
I'll pass your info to QA and see if they can reproduce it. You may also want to open a case with support so they can try and reproduce it from their end also.
