mjw1
Sep 03, 2010Aspirant
[SOLVED] NTFS Operation Not Supported (45)
[PLEASE JUMP HERE IF YOU WANT TO GO STRAIGHT TO THE SOLUTION] I have been struggling with a few permissions related problems and would really appreciate some help: This is my setup: - User mode...
mdgm-ntgr
Sep 15, 2010NETGEAR Employee Retired
you could try to chattr +i the file (I don't recommend this), but a better solution would be to change files referenced by include in the config file, much the same way as the Rsnapshot add-on adds a share.
You can untar the Rsnapshot add-on bin file, and then untar the files.tgz file and take a look at the source code for the rsnapshot add-on.
Instructions are found on the forum. You can google it.
