mjw1
Sep 03, 2010Aspirant
[SOLVED] NTFS Operation Not Supported (45)
[PLEASE JUMP HERE IF YOU WANT TO GO STRAIGHT TO THE SOLUTION] I have been struggling with a few permissions related problems and would really appreciate some help: This is my setup: - User mode...
mjw1
Sep 16, 2010Aspirant
mdgm wrote: you could try to chattr +i the file (I don't recommend this)
I'm not sure I understand how this would help. According to this article it would make files write-protected (http://www.mynitor.com/2010/08/25/the-i ... r-command/) so users would not be able to modify the file at all. What I really need is a way to only prevent ACLs being modified but to allow all other modifications. So users can create and modify Microsoft word documents, but the files only get imbued with vanilla unix file permissions rather than ACLs.
mdgm wrote:
, but a better solution would be to change files referenced by include in the config file, much the same way as the Rsnapshot add-on adds a share.
Are you referring to the files included from /etc/samba/smb.conf, for example /etc/frontview/samba/Shares.conf?
