mjw1
Sep 03, 2010Aspirant
[SOLVED] NTFS Operation Not Supported (45)
[PLEASE JUMP HERE IF YOU WANT TO GO STRAIGHT TO THE SOLUTION] I have been struggling with a few permissions related problems and would really appreciate some help: This is my setup: - User mode...
ewok
Sep 17, 2010NETGEAR Expert
#2 is probably more likely. I'll file a bug for it, but it will probably go into 4.1.8 at the earliest. This might be fixable short term with an addon.
