mjw1
Sep 03, 2010Aspirant
[SOLVED] NTFS Operation Not Supported (45)
[PLEASE JUMP HERE IF YOU WANT TO GO STRAIGHT TO THE SOLUTION] I have been struggling with a few permissions related problems and would really appreciate some help: This is my setup: - User mode...
mdgm-ntgr
Oct 15, 2010NETGEAR Employee Retired
CPU is still a major bottleneck on Sparc ReadyNAS devices. NTFS backup performance is better on the x86 ReadyNAS which use Intel CPUs. If there is a performance gain that's good, but performance is still going to be poor on Sparc ReadyNAS. On Sparc ReadyNAS using EXT3 is a good way to go. Enable Fast USB Writes on the NAS and install drivers on the PC to be able to use EXT3.
