mjw1
Sep 03, 2010Aspirant
[SOLVED] NTFS Operation Not Supported (45)
[PLEASE JUMP HERE IF YOU WANT TO GO STRAIGHT TO THE SOLUTION] I have been struggling with a few permissions related problems and would really appreciate some help: This is my setup: - User mode...
mjw1
Oct 15, 2010Aspirant
mdgm wrote: CPU is still a major bottleneck on Sparc ReadyNAS devices. NTFS backup performance is better on the x86 ReadyNAS which use Intel CPUs. If there is a performance gain that's good, but performance is still going to be poor on Sparc ReadyNAS.
Yes, I realize that the Sparc performance will always be less than x86. If Netgear offers to exchange my X6 for a 4 drive x86 version then I'd definitely sign up immediately, but unfortunately I think I'm stuck with a Sparc NAS like many others ;-) In which case I'd welcome a 48% performance improvement.
mdgm wrote:
On Sparc ReadyNAS using EXT3 is a good way to go. Enable Fast USB Writes on the NAS and install drivers on the PC to be able to use EXT3.
As far as I know there are no EXT3 drivers that are capable of read/write are supported on Windows 7 64-bit. I spent a lot of time trying to get them to work to no avail.
