mjw1
Sep 03, 2010Aspirant
[SOLVED] NTFS Operation Not Supported (45)
[PLEASE JUMP HERE IF YOU WANT TO GO STRAIGHT TO THE SOLUTION] I have been struggling with a few permissions related problems and would really appreciate some help: This is my setup: - User mode...
ewok
Oct 18, 2010NETGEAR Expert
mjw wrote:
At this point I am not asking that you even roll this version into RAIDiator. I'm simply asking that you help work directly with the NTFS-3G development team to troubleshoot the issue (at the moment we don't really know where the problem is) and identify a fix. Once this is done we can address the next step of whether or not this should be rolled out to users. Who knows, the problem might not even require a new version of NTFS-3G. We'll never know unless we do some tests.
Can you summarize what needs to be done?
