mjw1
Sep 03, 2010Aspirant
[SOLVED] NTFS Operation Not Supported (45)
[PLEASE JUMP HERE IF YOU WANT TO GO STRAIGHT TO THE SOLUTION] I have been struggling with a few permissions related problems and would really appreciate some help: This is my setup: - User mode...
mjw1
Oct 19, 2010Aspirant
ewok wrote:
I'll forward this to our build engineer and see what he can do. I was able to verify that copying a file with an ACL to an NTFS formatted drive produced an "Operation not supported" error.
Much appreciated. Did you perform the test on a Sparc device or an x86 device? Also, what version of ntfs-3g and what version of Linux were you running?
Also if you are able to determine what version of "fuse" we are using that could also be very helpful:
http://sourceforge.net/projects/fuse/files/fuse-2.X/
Thanks
