mjw1
Sep 03, 2010Aspirant
[SOLVED] NTFS Operation Not Supported (45)
[PLEASE JUMP HERE IF YOU WANT TO GO STRAIGHT TO THE SOLUTION] I have been struggling with a few permissions related problems and would really appreciate some help: This is my setup: - User mode...
ewok
Oct 25, 2010NETGEAR Expert
mjw wrote:
ewok wrote: I'll forward this to our build engineer and see what he can do.
Hi Ewok - Since about a week has passed I just wanted to check whether you ever heard back from your build engineer?
Not yet. Keep in mind his work queue is huge. :)
mjw wrote:
1. Where is the file on the Readynas that defines the mount options for ntfs-3g (I can't find it and it's not in /etc/fstab)?
2. We need to add the usermapping mount option (see NTFS-3G manual) and point it to a file somewhere on the main ext3 filesystem containing
::S-1-5-21-3141592653-589793238-462643383-10000
That would probably be in the USB mounting scripts.
mjw wrote:
3. When can this fix be rolled out to the rest of the Readynas community?
No ETA as of yet.
