mjw1
Sep 03, 2010Aspirant
[SOLVED] NTFS Operation Not Supported (45)
[PLEASE JUMP HERE IF YOU WANT TO GO STRAIGHT TO THE SOLUTION] I have been struggling with a few permissions related problems and would really appreciate some help: This is my setup: - User mode...
ewok
Nov 04, 2010NETGEAR Expert
Sorry, I've been a little bogged down.
Here is the user mapping file:
Debug output:
I'll take another look at the setup tomorrow.
april:~# cat /USB_FLASH_2/.NTFS-3G/UserMapping
::S-1-5-21-3141592653-589793238-462643383-10000
Debug output:
april:~# ntfs-3g -o debug,user_xattr,rw,sync,noatime,allow_other /dev/sda1 /USB/USB_FLASH_2> /tmp/ntfs-3g.err
utime_omit_ok: 0
Version 2010.10.2 integrated FUSE 28
Mounted /dev/sda1 (Read-Write, label "", NTFS 3.1)
Cmdline options: debug,user_xattr,rw,sync,noatime,allow_other
Mount options: rw,sync,allow_other,allow_other,nonempty,noatime,fsname=/dev/sda1,blkdev,blksize=4096
User mapping built, Posix ACLs in use, configuration type 7
unique: 1, opcode: INIT (26), nodeid: 0, insize: 56
INIT: 7.8
flags=0x00000003
max_readahead=0x00020000
INIT: 7.8
flags=0x00000041
max_write=0x00020000
unique: 1, error: 0 (Success), outsize: 40
