mjw1
Sep 03, 2010Aspirant
[SOLVED] NTFS Operation Not Supported (45)
[PLEASE JUMP HERE IF YOU WANT TO GO STRAIGHT TO THE SOLUTION] I have been struggling with a few permissions related problems and would really appreciate some help: This is my setup: - User mode...
mjw1
Nov 04, 2010Aspirant
ewok wrote:
april:~# ntfs-3g -o debug,user_xattr,rw,sync,noatime,allow_other /dev/sda1 /USB/USB_FLASH_2> /tmp/ntfs-3g.err
utime_omit_ok: 0
Version 2010.10.2 integrated FUSE 28
It looks like your driver was built from the 2010.10.2 standard release whereas the bug fix is in the 2010.10.2AR.1 (advanced release) which can be downloaded here:
http://www.tuxera.com/community/ntfs-3g-advanced/
Please can you try again with the 2010.10.2AR.1 release?
