mjw1
Sep 03, 2010Aspirant
[SOLVED] NTFS Operation Not Supported (45)
[PLEASE JUMP HERE IF YOU WANT TO GO STRAIGHT TO THE SOLUTION] I have been struggling with a few permissions related problems and would really appreciate some help: This is my setup: - User mode...
ewok
Nov 09, 2010NETGEAR Expert
If that addon works for you, I'd probably suggest sticking with it. It's unlikely that a bleeding edge version of ntfs-3g would make it into the official firmware release, but we can revisit this once the fixes reach the main branch.
