mjw1
Sep 03, 2010Aspirant
[SOLVED] NTFS Operation Not Supported (45)
[PLEASE JUMP HERE IF YOU WANT TO GO STRAIGHT TO THE SOLUTION] I have been struggling with a few permissions related problems and would really appreciate some help: This is my setup: - User mode...
mjw1
Feb 01, 2011Aspirant
ewok wrote: we can revisit this once the fixes reach the main branch.
Hi Ewok - The fixes have now reached the main NTFS-3G branch and can be obtained in STABLE Version 2011.1.15 (January 23, 2011). Care must be taken to compile using the --enable-posix-acls option (which is NOT enabled by default).
It seems that the 2010.10.2 Stable version made it into RAIDiator 4.1.7, but that version had a big endian bug that still unfortunately prevents the permissions functionality from working.
Please could you see if version 2011.1.15 can be put into the next releases for both Sparc and X86 with the --enable-posix-acls build option? When do you expect there to be a 4.1.8 firmware release?
Thanks again.
